Router keeps restarting
Hello @OCE_Michelle
Everything was replaced. The router is plugged into the normal socket - not the test one. Do I need to use the test socket for your checks?
regards.
Paul
Paul
Hi Paul,
Thanks for confirming. Would it be possible to connect the microfilter and router at the test socket for 24hrs to see if the connection is still unstable in this set up? If it is then the next step will be to arrange an engineer visit to the property.
Hi @OCE_Michelle
@I will connect to the test socket within an hour. Do I need to make contact in 24 hours or will you message?
Many thanks
Paul
Hi Paul,
Thank you. I'll check back in with you in the morning to see how the stability has been.
Thanks 🙂
Hi @OCE_Michelle
The filter is plugged into the test socket and the adsl cable is plugged into the filter.
Hope that’s right.
Regards.
Paul
Hi Paul,
Thanks for confirming and I'll check the stability again in the morning.
Thanks 🙂
Morning Paul,
I've re-checked the connection stats now and it looks like the connection may still be dropping. How have you found the connection since the router has been connected at the test socket?
Hello @OCE_Michelle
The connection dropped at about 9.30pm last night - as to whether it stopped other times I don’t know as I’ve not been in the house. My daughter was on Xbox yesterday and I’ll ask when she wakes if she lost connection.
regards.
Paul
Hi Paul,
Ok thanks for confirming. Would you like to go ahead and arrange an engineer visit to the property?
Hi @OCE_Michelle
What’s normally involved? Will they check my wiring between the arrival
point at my property and the master socket? Also do you know out of interest what kind of costs there might be?
Paul
Hi Paul,
I've included a Help Article below which contains more information.
Engineer charges
Thanks @OCE_Michelle
My service wasn’t perfect with my last provider so maybe there is a bigger issue. Please arrange for an engineer visit. I think it best to get checked properly.
Many thanks
Paul
Hi @OCE_Michelle
I have just tried my landline and I have no dial tone. All cables are in the test socket so maybe this is what the issue is. Any news on when an engineer might be coming? I need to go back to the original socket so I have my phone line.
Paul
I'm sorry for the delay. Is there a dial tone if you just connect the phone to the test socket?
Hi @OCE_Michelle
I connected the phone straight to the test socket without the filter and there is a dial tone. Then I connected through the filter and there was a dial tone. I then realised the line I’d checked this morning was an extension line.
I have my main phone and the extension going through a splitter. Main phone works but extension doesn’t. This is with and without the filter in the test socket.
I guess an engineer will be able to figure it.
Regards.
Paul
Hi @OCE_Michelle
The router has reset itself 3 times in the last hour or so. I still have it plugged in to the test socket.
Paul
Hi Paul,
If you'd like us to arrange an engineer visit can you confirm:
Hi @OCE_Chris
I accept the engineer charges. If possible an AM appointment would be preferred.
Paul
Paul
Hi Paul
I've booked the engineer for Monday September 07 2020, AM (8am-1pm) - please let us know how you get on
(just noticed your earlier post about the extension socket not working, please note that removing the master socket faceplate will disconnect any extension wiring/sockets)
Hi @OCE_Chris
The extension just plugs in like the main line.
Thanks for booking the engineer. I’ll discuss with him when he’s here. Can I confirm - he’s checking from the point the phone line hits my property to the master socket right? He’ll check that wiring?
Paul
