Router login details
4 REPLIES 4
zofbtb
Having a play with my new router and see the latest firmware adds "reserve IP" which is great. The only thing I can't find is the username and password - the Phonenumber@talktalk.net bit
There isn't one, TalkTalk use remote authentication.
zofbtb
But TT's routers can be used with other ISPs (ie you can buy them) so thought somewhere in the GUI there'd be the 2 fields
If you change from DHCP to PPP the setting will become available, but you should not do that if you are on a TalkTalk line.
zofbtb
