Router lost sync, bright sparks engineer being sent
33 REPLIES 33
If I have a line fault , what will a bright sparks engineer do that a By engineer can’t, I’ve have also tried different routers and filters so must a be a line fault that it won’t sync
Hi @Paza02
Hi Paza02
Do you have a dialtone? (can you make calls ok)
I have a dial tone , can make voice calls, just haven’t been able to sync to the internet since Friday , have tried different router, micro filter and cable , not sure what else I can do, happy to try anything as getting through my Mobile data quickly
Hi Paza02
The line test is detecting a possible fault with the landline service. Thanks for confirming that you do have a dial tone. Is there any noise on the line?
There no noise on the line at the minute, there normally a crackling noise but appears fine
Here is my old landline
Router 
Hi Paza02
Would you like me to cancel the TalkTalk engineer visit and pass this fault straight over to Openreach?
Yes please as Im 100% confident it’s not internal , I’m using the master socket, replaced everything during testing
Hi Paza02
I'm just sending you a Private Message to confirm some details.
Thanks Debbie
Hi Paza02
Thanks for the Private Message.
I have cancelled the TalkTalk engineer visit and passed this fault over to Openreach. A line engineer will investigate this fault and we should receive further updates within the next 48hrs.
Thank you , I take it don’t reply to this message that ive just received below
TalkTalk update: We're just checking in after your recent engineer visit. If you're still having any problems with your TalkTalk services, simply reply to this message and one of our team will be able to help. (Standard mobile charges may apply).
Hi Paza02
No this will be in regards to the TalkTalk engineer visit. If you post back on this thread tomorrow then I can check for further updates on the fault raised to Openreach.
Any update ?, will someone need to be there as no one at home at the minute
Regards lian
Hi Paza02
I'm checking for updates now and I will post back on this thread shortly.
Hi Paza02
The next step will be to arrange an engineer visit to the property (Openreach visit)
Please can you confirm possible engineer charges and provide your availability for this visit AM and PM?
Define am & pm as have to change shifts at work? Can be at home from 1230 tomorrow if it helps
Hi Paza02
AM is (8am - 1pm) and PM is (1pm - 6pm)
If you could provide a couple of dates and we will arrange the first available.
Wednesday PM
Friday Am
Monday Am
