Router randomly disconnects - DNS issues
13 REPLIES 13
mrkinny
can someone assist, when browsing on laptop (wifi) my page will freeze (different sites not just the one) I click on Troubleshoot and windows checks a few things at at the end it says dns resolved (gateway) and everything works again.
I have used the chat facility 3 times and each time they run tests but as I follow up they cant answer what the problem is.
I read here previously someone has a similar problem and an advisor sent a replacement router out and this fixed his issue - Can I get this?
I have changed the dns in router settings, updated all software, rebooted router several times and plugged directly into the maser socket all with the same problem, so I think it is hardware related.
thank you.
MrKinny Windows, Linux and Android.
OCE_Debbie
Hi mrkinny
Apologies for this.
I can send a replacement router for testing, would you like to test with the same router you currently have or a different make and model?
mrkinny
it is the sagem Fast router - i'm not fussed just whatever will give me the same performance as I have had. preferably whatever is newest
thank you for getting back to me so quickly
regards
mrkinny
TalkTalk Wi-Fi Hub Black seems to be the latest model - could i test that and see if fixes the issue?
OCE_Debbie
Hi mrkinny
mrkinny
WILL DO - MANY THANKS
OCE_Debbie
mrkinny
10 out of 10 for service, replacement router arrived today 🙂 - have just swapped over unit itself to test service for a few days, if all goes well I will replace the cables and box up old equipment for return.
can I ask if I need to mail old equipment back as I stay near a council run facility that processes WEEE (lets me keep my carbon footprint down or else Greta will get onto me)
thank you once again and hopefully the issue is resolved
OCE_Debbie
Hi mrkinny
Yes that will be fine 🙂
mrkinny
oh well of was worth a try,
the issue is happening on the replacement router as well, what are my options, I've checked all my equipment elsewhere and it works fine but both routers are doing the same (DNS/internet dropping)
not good 😞
OCE_Michelle
Hi mrkinny,
I'm sorry to hear this. I've re-run the line test which is still clear and I can see 1 re-connection in the last 4 days. Has the connection been dropping off more than this? Was the replacement router the same make and model?
mrkinny
same make and model.
I rebooted the router but still get the DNS error which requires me to troubleshoot in windows, once thats completed my connection is restored.
it was great for the first day but then it was happening just as often as before.
OCE_Michelle
Hi mrkinny,
We're currently looking into this specific issue at the moment and we'll let you know as soon as we receive an update back.
OCE_Michelle
Hi mrkinny,
We've received an update to let us know that this should now be resolved. Please let us know how your connection and performance compares now.
