Hi I hade this problem some months back and it has now returned. I have to reboot my router daily. As the download speed drops from 21-22mps to 8-10 mps. This was the original problem I had and was helped by an OCE who sent me a new router and everything was fine until now. Please help! Ray from Cornwall.
Hi Razor-sticky71,
I'm sorry to hear this. When the speed drops does this affect both the wired and wireless speed? Are you currently using the 3782 or the HG633 router? What was the make and model of the previous router also?
Hi Michelle,
Thanks for the reply. I rebooted the router again last night and the speed went up to 22mps and I have checked it again this morning twice once just before replying to you and it was 22.9mps download. I only ever use wifi as when I tried ethernet it made no difference. all those months ago with another OCE I did all sorts of tests and tried the 3782 router which was no better then I was sent a new HG633 and all had been fine until just recently. I alway know when the speed has dropped as when I am surfing the web the reaction is slow. My previous router was also a HG633. Is there an updated model or a newer type that doesnt have these problems as I see on the forum I am not the only customer to experience these problems.
Razor
Hi Razor-sticky71,
Thanks for confirming this. Do you still have the 3782 router at all?
No I sent it back after the testing as it was no different to the old HG633. The new HG633 which was supplied after is the one I currently have.
Razor.
Hi Razor-sticky71
Would you like to test with the DSL3782 router again?
I dont really thnk its worth it Michelle as it didnt work before! Do Talk Talk supply any other type of router apart from HG633 and the DSL 3782?
Razor
If you are having the same issue with multiple routers then the chances are that the problem lies elsewhere. Is everything OK with your landline? Are you connected at your master phone socket and tried the test socket if you have one?
Hi Razor-sticky71,
I've re-run the line tests which are still clear at the moment and the sync speed looks consistent. As you've already tested with 2 different routers then we can pass this over to our Network Team for further investigation as you shouldn't have to keep rebooting the router to increase the throughput speed.
Just before we pass this over would it be possible to retest wired so we can confirm that this is not only related to the wireless connection?
Does the master socket have a test socket and is the voice service also ok with no noise?
I am connected to the main socket and I have no problems with my landline there is no test socket. I have tried both wifi and ethernet and the results are the same. I have run another speed test again to day via supportal test and it was 22.3mps download. I will continue to monitor speed tests to see if it remains constant.
Razor
Hi Razor-sticky71,
Ok thanks for confirming this. If the wired speed does drop again then could you run a wired ping and trace route before you reboot the router and post the results into the thread. We can then pass this over for further investigation.
Hi Michelle,
As I explained previously i use wifi all the time as to use the ethernet means means me climbing up a ladder to the loft where the main socket is connected carrying the laptop under my arm. I am now in 72 and i find it very difficult to do! Can i do the ping and trace via wifi ?
Razor
Almost its just outside it. I Live in a barn conversion so its not a conventional loft. I.E. not a door in the ceiling.
Razor
That may explain the poor wireless throughput? Although I thought you said previously that you had tested with a direct ethernet connection also, hence my confusion.
Do bear in mind that your broadand service level is geared to delivery at your master telephone socket with a router presumed to be connected nearby and wired connections beyond that. Anything else is subject to many vagaries.
Hi Razor-sticky71,
Could I also confirm, have you tried a few different wireless channels to see how the speeds compare?
Sorry for the long delay in answering as I have been trying all sorts tests but they all come back the same. Anyhow I have been running a supportal speed test each day for a week and the speed stayed constant at 22.5mps download however the upload has dropped to 1.4mps. Finally today I checked my speed via supportal and once again has dropped to 7.9 mps download 1.4mps upload so I thought I would reboot the router. When I typed in the router address 192.168.1.1 to access the router page nothing happened. So was unable to reboot via my computer. I did reboot however from my mobile phone!!
Hi Razor-sticky71
The line tests have not detected any faults and your line is in sync at 24mb.
It may be worth arranging a TalkTalk engineer visit to investigate the drop in throughput speed.
Hi Debbie,
Its strange my speed has been constant all week until today. What I cant understand is why all of a sudden when i put 192.168.1.1 in my web browser (microsoft Edge) nothings happens so it must be a problem with the Browser as when I used my Mobile phone which uses Google i was able to access 192.168.1.1 and was able to reboot the router and funnily enough whe i ran another supportal test it was 24.3mps which is the highest its evet been This also relates to your test which was 24mps
Razor.
