Router resets randomly throughout the day
8 REPLIES 8
kahyang
Hi TalkTalk team,
My router randomly resets a few times each day (light goes orange, wifi disconnects) and then reconnects after 1-2 minutes. I have done a line test and nothing has flagged up. Very frustrating as working from home. I think the issue could be the router. Would this be something Talktalk could look at? Thank you.
Skynet_TX
Hi @kahyang,
If you have a landline phone can you check to see if that is working normally (i.e. you have a clear dial tone and no noise on the line).
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
Then they will hopefully be able to respond to this post within two or three working days. You may get faster support from the live chat or by phoning up during opening hours.
The staff will be able to test your connection and router, and if they did suspect a fault with the router they would be able to arrange a replacement.
kahyang
Hi there, thank you for the below. I did speak to an agent and have connected the microfilter straight into the test socket. It still drops my internet/router.
I have now updated my account, thank you.
kahyang
Hi again,
I have been trying to contact customer service but the chat is always busy, and the line doesn't go through. The latest update I see on my account is that "there is a network issue" on my services. Please can you confirm if this means Talktalk has acknowledge post-test the issue is with the network, and not my property? Please advise next steps if possible.
Thank you.
OCE_Debbie
Hi kahyang
I'm really sorry for the delay.
I've completed a line test which hasn't detected any faults but I can see re connections on the line.
Would you like me to send a replacement router for testing to rule out any possible faults with the router?
kahyang
Hi Debbie, yes please this would be much appreciated.
OCE_Debbie
Hi kahyang
kahyang
Hi Debbie,
Unfortunately the new router has not worked. It is still dropping connection. It is random. Yesterday there was no dropouts, today it dropped about 5 times. I don't think it's my internal line issue, must be something with the line?
I'm getting quite frustrated.
Thank you.
OCE_Debbie
Hi kahyang
Is the replacement router currently connected at the test socket?
If the connection is still dropping with a different router, filter and adsl cable at the test socket then the next step will be to arrange an engineer visit.
