Router settings
ANSWERED
3 REPLIES 3
Super Duper Contributor
Hi just check my router settimgs to see what devices are connected to the network and it lists about 25 devices of which most are repeated such as 3 Xbox's 3 TV's 3 google mini's and so on.
Why is this happening?
Some devices are listed as the correct device but some also have a mix of  numbers and letters and then a picture of a ?
Can i change the names of the listed devices so i know what they are?
Solution
The router will list previously connected devices and you can usually give a device a more friendly name by editing the details.
Thank you for that
How would i find out what the devices are with the mixed numbers and letters are?
The numbers etc are usually the mac address of the device.
I would list only the active devices and change the names of the ones you are familiar with.  Alternatively, I usually reserve an IP for each device I use a lot so I can identify them.
