SAGECOM FAST 5364-3.T8 Power Issue / Router Dead
7 REPLIES 7
wheatley000
I am experiencing an issue with the above router. It has no power (no lights and not broadcasting a signal), despite being plugged into a socket that works - I have tested other devices/appliances in the same socket successfully.
It seems to be a known fault, for which the solution is a new piece of hardware:
https://community.talktalk.co.uk/t5/Fibre-Broadband/New-router-SAGEMCOM-Fast-5364-3-T8-No-Power/td-p...
Please could you arrange this as soon as possible.
wheatley000
Hi wheatley000
Can I just check if you have also tried factory resetting the router using the pin hole reset?
I can then send a replacement router.
wheatley000
Yes, I have tried inserting a pin to do a factory reset, but this was not successful.
Hi wheatley000
Please can you add your TalkTalk telephone number to your Community Profile. I can then send a replacement router.
wheatley000
Thanks, how do I do that?
Hi wheatley000
wheatley000
Thanks, the new router works properly.
glad our team have been able to help.
