SSL VPN connection drops still occurring
9 REPLIES 9
duds2000
Hi Team,
I've been a TalkTalk Fibre broadband customer for 2 years. I work from home for a few hours a day each week, and often need to join meetings in the evenings, connecting to my company's SSL VPN service using Mobile VPN with SSL client.
This has worked fine up until 15/01/19, but then all of a sudden I am experiencing problems with my VPN connection dropping. I have been trying to get this sorted using your chat / text message service for 5 days continuously, and there has been no success (I think that service is a complete waste of time). I am sure you can appreciate how frustrating this can be let alone how disruptive it is to my ability to work from home. I have had to resort to using the telephone today to join meetings due to the instability of my VPN connection, in turn using all my mobile data allowance.
I have run Broadband status, and speed, checks at the times when I have expericed VPN drops and no issues are reported.
I have tried connecting using a friends broadband provider and everything works fine. I have also tried using a different PC at home to connect to the VPN, and that also fails. I believe this points to the router and not the VPN software.
I was otherwise a happy TalkTalk user up until a week or so ago, and therefore would like to get this issue resolved as I need to have a stable, reliable VPN connection otherwise I will seriously have to consider changing my broadband provider. Therefore I would really appreciate any help you can give to get this resolved once and for all.
Dave
Hi Dave,
I'm sorry to hear this. Which router are you currently using? (make and model) . Does the connection only drop when using VPN? Is it stable the rest of the time?
duds2000
I have a Fast 5364 sagemcom. The connection only drops when I am using VPN.  I have tried using it on other networks and the VPN works fine, for example I can use it when I am staying at hotels, or in restaurants or when I am at other people’s houses, it just doesn’t work at my house using your router / broadband.  It did work fine up until 15/01/19 then it started dropping connection when using VPN. I have tried rebooting the router several times but there is no effect
Hi Dave
I've made some changes, please can you test this again and let us know how you get on?
duds2000
Hi Debbie, no it is still the same. I have tried rebooting the router too, but still no luck.
I am trying to connect using Watchguard Mobile VPN with SSL client, it connects, but then keeps dropping off after a few seconds
Hi duds2000,
I can send you a different make and model of router to test with, would you like me to arrange this?
duds2000
yes, please could you send me a different make and model of router to see if that works. I have tried the same router and the results are no different, the VPN connection keeps dropping
Hi duds2000
duds2000
It is now working fine with the new router. Thank you very much for sorting this
Hi duds2000
That's great news, thanks for keeping us updated 🙂
