Sagemcom Fast 5364 Firmware upgrade request
9 REPLIES 9
Hi Admins,
Can someone please check if my router needs a firmware upgrade as Ive done some work on it today and the  interface seems mighty slow to me.
thanks
Steve
Hi @SteveElmo your post has been flagged for assistance and you should hear soon.
Of course if it was the work you did, a factory reset might solve it as I'm afraid it won't be possible to upgrade the user.
Great thanks. By ‘work’ all I meant was to add a port forward rule and a dyndns entry
Hi @SteveElmo sorry my sense of humour got the better of me no offence intended.
I'm sure @OCE_Chris or @OCE_Karl will pick up your request and check your firmware.
Hi Steve,
I've checked and the router currently has the latest version of firmware. How is your connection at the moment?
the issue I had was slow menus in the router. Having said that I’ve just had to tether my phone as the router dropped out completely
Hi Steve
Would you like me to send a replacement router for testing?
That sounds like a plan. It dropped out 3 times today as well.
Steve
I assume this will be at no cost to me?
Steve
A router is on the way to you for testing, at no cost to you.
