Sagemcom Fast 5364 Not Issuing IP Addressess Needs Regular Reboot
ANSWERED
7 REPLIES 7
bill80
Please could I get some help with our TalkTalk Wi-Fi Hub?
For the past week we've been having issues with the Sagemcom Fast 5364 not Issuing IP Addresses. Which can only be resolved by rebooting the Router every day sometimes more.
I think it might be a fault with the Router itself because we have a solid connection to the internet with 68mbps download and 19-20mbps upload speeds.
WiFi signal is fantastic, we have 3 Tablets, 2 Phones, 2 Smart TV's and Sky Q running. All were working really well until a week ago. The problem is really apparent with the PlayStation 4, which is connected via Ethernet directly to the Router.
I get an error message saying "Failed to issue IP address in time" once I reboot the Router the issue resolves for a while.
I've had the PS4 looked at by engineer, apparently there is no problem with the console as I connect directly via Ethernet. had Sky Engineer check our Sky setup and again they report no issue with that.
I wonder if it would be possible to get a replacement Router please? As both engineers have said it is highly likely there is a fault with Router itself.
The Firmware version: SG4K1000260
Thank you
Bill Gunn, Musician, Author, Creator and dabble in Technology at weekends
bill80
@KeithFrench Thank you very much, really appreciate it. I've updated profile information now.
Hope you have a good weekend
OCE_Chris
Solution
Hi bill80
Sorry to hear you're experiencing problems with your router. Can you initially try resetting your router to factory default settings and then retest. If this doesn't resolve the issue please let us know and we can look into it further
bill80
Hi @OCE_Chris
Thanks for this. I've just reset the Router and everything looks to be back up and running again!
Fingers crossed...
Thanks again
Bill
OCE_Debbie
Hi Bill
That's great, thanks for keeping us updated.
Debbie 🙂
bill80
Hi, @OCE_Debbie @OCE_Chris @KeithFrench
Thanks again for your help, hopefully I'm not tempting fate. But ever since I did the "pinhole reset" my connection is stable again. Excellent speeds too!
Ran a Speed test using Speedtest by Ookla Android app. I'm getting consistent 69 - 72Mbps DL and 18 - 19Mbps Upload.
Very happy indeed. When I was experiencing issues I read about Firmware updates, do you install them in the background or is it something the user/customer has to check periodically?
It's great to have everything up and running again. I am still amazed at how much of an impact having an internet connection has on our day-to-day life. If it goes down it's like losing a limb!
Hope you have a great weekend! 😁
Cheers,
Bill
OCE_Karl
Hi Bill
Firmware updates are pushed automatically and your Hub should be on V2600t.
If a firmware update is missed, we can push this manually from here.
