Sagemcom WiFi Hub power supply died
9 REPLIES 9
My upgrade to fibre on 8th Oct. has been working great for 2 weeks but last night the internet stopped working and the LED on the Sagemcom WiFi hub was off. To check if it was a hub or power supply problem I measured the power supply output with a multimeter and got 0 Volts.
I borrowed a similar power supply from another device just to test the hub and with the other supply everything worked correctly again.
Can you please arrange to send me a replacement power supply for the hub.
Rich
Richard Young
Hi @Old_Guys_Rock
Hi Keith,
Thanks for the response.
My contact details are up to date on the system.
Rich.
Richard Young
A replacement unit is on the way.
Hi Karl,
Thanks very much for arranging a replacement.
Do you want the faulty unit returning for investigation or shall I drop it in the bin ?
Kind Regards,
Rich.
Richard Young
Hi Old_Guys_Rock,
Yes, please can you return the router. Did you receive a router returns bag?
Hi Michelle,
A complete router kit and a returns bag arrived today.
Thanks very much for the fast replacement.
I only needed a new router power supply as the original one died and the current router works fine.
Shall I just swap the power supplies and return everything else as brand new and unused or do you want me to swap everything ?
Rich.
Richard Young
Hi Rich
We can't send a replacement power cable on its own. Please can you keep the new router and cables and return the old router using the returns bag.
Debbie 🙂
Hi Debbie,
The replacement router and power supply are now installed and working.
I have just handed over to the Post Office the original router and everything that came with it for return. That should arrive at the returns depot by Monday at the latest.
I did factory reset the router to remove all my custom settings.
Thanks very much for your help with this problem and supplying the replacement so quickly.
Rich.
Richard Young
Hi Rich,
Thanks for the update 🙂
