Sagemcom router: changing router IP address
1 REPLY 1
I've recently received the Sagemcom WiFi router as a replacement for my HG635.  However I can't use it because my LAN uses IP addresses 192.168.0.# but the Sagemcom IP address is 192.168.1.1.  Can you advise how I change the IP address to 192.168.0.1 and set the DHCP server to assign addresses to 192.168.0.#?  Thanks
It is easy to do, go to:-
Dashboard > See Wi-Fi Settings > Manage Advanced Settings > TalkTalk Wi-Fi hub > DHCP
The router’s IP address & the DHCP server’s IPv4 address pool (address range) can be set here. You will obviously need to change both of these in one go.
