Scam phone call threatening to cut off Phone and Broadband a Warning
4 REPLIES 4
paulst955
Wizz Kid
Hi ALL, I have received about 3 phone calls in the last week or so threatening to cut off my Broadband and phone line from phone NO 02106776373, Its a recorded device that says press 1 or press 2 for different options. I have not done this just put the phone down.  I assume if you do press option 1 or 2 some con will happen. SO ALL BE WARNED DO NOT PRESS ANY OPTIONS JUST HANG UP.. Can someone at talktalk investigate this phone no .
Cheers Paul
PS also posted this in phone section
Divsec
Thanks Paul, try  callsafe stops them in their tracks however many numbers they use.
paulst955
Wizz Kid
Thanks, have set up call safe hope it works..
Divsec
Hi Paul good stuff, let's know how you get on.
D
Hi paulst955
Apologies for this.
You can also report this call using Check and Report
