Settings for my Panasonic digi box
1 REPLY 1
Hello.
I'm trying to setup my Panasonic Digi box to run via an ethernet cable.
I need
IPS address.
Subnet mask.
Gateway address.
Primary DNS
Secondary DNS.
Thanks in advance
Ian
Hi Ian
most digi boxes should identify the network connection automatically.
Your external IP address is dynamic and will change, unless this is referring to the IP address of the router (192.168.1.1).
The subnet is 255.255.255.0
Gateway address is the router 192.168.1.1
For DNS you can use google 8.8.8.8  &  8.8.4.4
