First noticed broadband speed had dropped from circa 27 to 9 when I tried to watch Sky football on my desktop last Friday (18/10/19).
My 3 year old Dell i5 Windows 10 desktop is hard wired to the router which is immediately adjacent to the router. Router is within 1 metre of the Openreach socket.
I've tried all the usual things
1. Reboot router
2. Switched to wifi connection.
3. Reset adapters/checked for more up to date drivers
4. Disabled the internal wifi adapter and tried an external USB wifi adapter
5. Uninstalled TalkTalk F Secure (ie went back to windows anti virus)
6. Uninstalled the last two Windows 10 updates
7 Updated to F Secure Online Defender anti virus
All without any success.
Current Ookla speed test is d/l 8.4 and u/l 9.4.
This is somewhat similar to when I first joined TalkTalk. With Plusnet I was getting a d/l speed of circa 38. Swopped over routers and speed was 9. Talk Talk advised connection to router was 40.
Managed to overcome when I installed the F Secure and got d/l speed of 27 which I could live with.
Hope someone can help.
Please log onto your router & get me a copy of your DSL Line Stats.
Hope this is the right info.
Internet connectivity - IPv4
Connection Type - DHCP
VLAN id - 101
Addressing Type - DHCP
DNS - Obtain DNS automatically
DNS1 - 79.79.79.79
DNS2 - 79.79.79.80
Dashboard says d/l 40 & u/l 9.7. Recent speed test was 9.4 & 9.1.
xDSI data
D/L Actual Rate 40000; Max Rate 42234, Noise Margin dB 7.4; Attenuation dB 21.1 & Power dBm 14.2.
The corresponding U/L figures are 9723, 9723, 6.3, 0.00, 7.4.
Your router is sync'd right at top speed. I have asked one of TalkTalk's OCEs to pick your thread up and investigate it for you.
Hi MickC1,
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault and the connection stats look ok. Please can you switch the router off for a full 30 minutes and then run another wired speed test so we can see how the throughput speed compares following this.
Hi Michelle,
Switched router off for 30 minutes plus.
Ran TalkTalk speed test - result D/L 10.6; U/L 9.3
Hi MickC1,
Thanks. Could I just confirm, was this a wired speed test?
Yes.
Although the router is immediately next to my desktop I use a wired connection.
As a check.
Did another speed check via wired connection and results are D/L 10.9 & U/L 9.3.
Immediately did a speed check via wifi connection and figures were 11.1 and 9.2.
Not much different.
Hi MickC1,
Thanks for confirming this. I've re-checked the connection stats again and the line test is still clear and the sync speed looks ok. Do you have a different device that you could run another speed test on for comparison?
Borrowed a laptop and ran the talktalk speed test with laptop wired to the router - D/L 37.6; U/L 9.1.
At the same time the same test with my desktop, result was D/L 11.8; U/L 9.3
Hi MickC1,
Thanks for testing this. @KeithFrench, would you be able to offer any advice in regards to the slow desktop speeds?
Please supply details about this pc, plus is it doing anything in the background such as updates, cloud storage etc?
Computer is a circa 3 year old Dell Inspiron Desktop
Intel Core i5-6400 @ 2.7Ghz
x64 based processor
RAM 8Gb c50% used
HDD 1Tb c 10% used
Nividia GT730 display adapter
Qualcomm wifi adapter
Realtex ethernet adapter
Currently using Windows Firewall and AVG Free anti-virus
Dont use any cloud. Backup to an external HDD
Task Manager currently
4 APPS - firefox, device manager, windows explorer, task manager. Only figure of note is firefox using 650 to 750Mb
CPU ticking along at c5% but will blip up to c30% due to AVG,etc.
Performance of Ethernet shows no send or receive except for occasional blip of S(end) 8 to 16kbps and R(eceive) 8 to 64kbps
72 Background Processes but all figures are minimal.
Other background. When I first moved to TalkTalk in October 2018 my speed with Plusnet c38 dropped to 9 when I swoped over routers. I eventually got a speed of 27 when I installed the F Secure anti-virus which I've been happy to live with - hence I've tried windows anti-virus plus AVG and the updated F Secure - all without any change.
Always use a wired connection to the Desktop which is adjacent to the router and router is within 1 metre of the fibre socket.
Thanks, is the Ethernet connection running a minimum of 100M Full Duplex?
Checked the Realtek adapter and it was set to "auto navigation" - changed to 100Mbps full duplex - no change to d/l speed
I expected it to be set to Auto-Negotiation, but that can sometimes fail, which is why I asked not what it was set to, but I asked you to confirm what it was actually running.
You can get some of this from "Network & Internet settings in Windows 10 followed by "View your network properties", but one of the few ways to be certain about Duplex is to run this PowerShell cmdlet:-
Get-NetAdapter | ft Name, Status, Linkspeed, macaddress, fullduplex
In Windows 10 Powershell - Get NetAdapter
InterfaceDescription: Realtek PCIe GBE Family Controller
ifIndex: 15
Status: Up
MacAddress: F4-86-39-93-C1-CE
LinkSpeed: 100Mbps
Does this help?
You missed off the all important fullduplex on the end of the cmdlet.
