Slow Speed, IP Address Reservation and Firmware update
27 REPLIES 27
allesclar
Afternoon all,
Fibre transfered over last night from Sky. Straight away a 10% drop but i am happy to wait for it to smooth out for now. (Was quite happy to using Sky router for now but dont want it affecting potential linespeed in the intial week or so).
I am trying to allocate IP Addresses within my home network via the TalkTalk router. I am unable to do this, nor modify IP addresses allocated to devices already connected to the TalkTalk router, when using DHCP.
I have seen on the forum that the latest firmware version addresses this. Please can i have the latest firmware pushed to my device.
Current version on router is SG4K10001400t.
I have asked one of TalkTalk's OCEs to pick your thread up and upgrade it for you.
Hi allesclar,
  • Name
  • Telephone number
  • Alternative contact number
allesclar
Thank you for the replies.
I have done as asked and updated my information.
I didn't do it via chat as they directed me here first after i had previously asked on chat.
Cheers
Hi allesclar
I have updated your router firmware, please let us know how the connection compares following this.
allesclar
Hi Debbie,
Many thanks, i can now allocate IP addresses.
However the speed is still the same.
Kind regards
Hi allesclar,
Thanks for the update. I've run a test on the line which hasn't detected a fault. Just to confirm, what speeds were you previously receiving?
allesclar
Hi Michelle,
I was getting around 63-64 Mbps with a ping around 5-7ms.
The best i have gotten so far is around 57 Mbps with a ping around 25-30ms.
I have noticed within the router settings, there is a maximum connection speed of around 65343 bps but the connection speed is only at 58344 bps. When i last checked that is.
Kind regards
Hi allesclar,
Thanks for the update. Are you running the speed tests wired or wireless? I can see a few re-connections on the line which can affect the sync speed. Is the connection unstable or have you been rebooting/switching off the router?
allesclar
Hi Michelle,
Thanks for the reply.
I am running wired cable direct off the router into my laptop.
I did get around 63Mbps the other day, but have noticed it reduce down to 58-59Mbps.
Can this be looked into further as i will not be in a position where i have to keep restarting my router every few days to get a better speed.
How does your sync speed process work, as it looks like from my side, it has gradually gone down (bandwidth wise) rather than increase?
Kind regards
Hi allesclar,
I'm sorry for the delay, is the router currently switched off?
allesclar
Hi Michelle,
Router is online.
Kind regards
Hi allesclar
I can see re connections on the line and this can affect the sync speed.
How often are you rebooting the router? Please can you leave the router at the test socket for 48hrs without rebooting? We can then check to see if the speed increases.
Your line is currently in sync at 59.3mb.
allesclar
I have had the new firmware pushed, which allows me to change the name "favourite" of devices connected.
However on a router restart, this wipes the information and any names/icons allocated to a said device.
Is this something that can be fixed please?
Kind regards
We have fed this back to the devices team previously and this is to be fixed in the next firmware release.
allesclar
Hi Karl,
Many thanks for the reply.
Kind regards
allesclar
Speeds are still lower than before I switched and have not improved over 48 hours.
I have got 65Mbps before and then it went back down to 59Mbps after a reconnection.
Kind regards
Hi allesclar,
Is your router currently connected to your test socket?
allesclar
Morning Chris,
It is not connected up to the test socket.. We do not have a test socket which are only based on older legacy phone line connection sockets.
I have attached a photo for reference.
Kind regards
