Slow and unstable Internet for 5 days - Constant DNS errors - New wifi Hub
4 REPLIES 4
James McC
I am having issues with all devices on both wifi and hard wired direct to router.
I have spent 5 + hours on the phone trying to get this resolved , sent ping results etc.
The issue is exactly the same and we are very close to just leaving Talk Talk forever.
Technical say that there is no fault on our line.
When running download tests I get max 10 mbps down and 1 mbps up , most of the time I am getting less then 1 mbps up and down.
When browsing we get constant DNS errors , pages are slow to load or just fail entirely.
This is a constant fault.
We are supposed to get 57 mbps down and 20 mbps up as a minimum.
Can someone help us on this forum please ?
OCE_Michelle
Hi James McC,
I'm sorry for the delay and I'll take a look now. I've run a test on the line which hasn't detected a fault and the connection looks stable for almost 48hrs. Just to confirm, when did you last experience drops in connection?
Is the voice service ok with no noise on the line? In regards to the speed, the sync speed looks ok. Have you recently tried switching the router off for a full 30 minutes and then retested the throughput speed again? If the sync speed is ok, however the throughput speeds are much lower then we usually advise trying this as this will reset the current session.
James McC
The service went back to normal last night.
I didn't change or do anything.
No idea what this means in terms of the future reliability.
Please close the thread.
Thank you for your assistance !
OCE_Michelle
Hi James McC,
Ok thanks for the update and please let us know if you need any assistance.
