Slow fibre Speed
39 REPLIES 39
fonzig
Hi all,
The usual slow fibre speeds. Usually get around 76mb but it has dropped to as low as 8mb.
I'm connected to the test socket, I've left my router off overnight  (27th to 28th) to reset DLM.
leefoster.tech
OCE_Michelle
Hi fonzig,
I've run a test on the line which hasn't detected a fault, however I can see that the sync speed has dropped. Just to confirm, is the voice service ok with no noise on the line?
fonzig
Hi Michelle,
Just tested a voice call. All seems normal, just a very slight hiss in the background, nothing more than usual.
Lee
leefoster.tech
OCE_Michelle
Hi Lee,
Thanks for testing this. Do you have an alternative router that you could connect so we can see how the connection stats compare?
fonzig
I have my original HG633, I will swap the vigor for this.
Lee
leefoster.tech
OCE_Michelle
Hi Lee,
Thank you. You may not see an immediate increase in sync speed as it can take DLM between 24-48hrs to make changes to the speed if the connection remains stable. If their is no improvement then we can ask our Network Team to take a look.
fonzig
New router stats:
leefoster.tech
fonzig
No worries, I will check over the next day or two.
leefoster.tech
OCE_Michelle
fonzig
Hi @OCE_Michelle,
Left it for 4 days and there has been no change to my internet speed, still only getting around 13mb.
leefoster.tech
OCE_Chris
Hi fonzig,
I've logged this over to our network team, can you bump the thread tomorrow and we'll check for updates
fonzig
Thank you, Chris.
leefoster.tech
OCE_Chris
fonzig
*BUMP* for an update as requested.
leefoster.tech
OCE_Chris
Thanks for the bump, I'm chasing this up with our network team. I'll let you know when I receive an update
OCE_Chris
Hi fonzig,
The next step will be to arrange an engineer visit to investigate further, to do this can you confirm:
I've also PM you to confirm some other details
fonzig
Hi Chris,
I've replied to the PM.
I accept possible charges.
AM time slot would be the best.
Lee
leefoster.tech
OCE_Chris
Hi fonzig,
Thanks for the PM
Are you available any weekday for the AM appointment?
fonzig
Yes, apart from the 23rd.
leefoster.tech
OCE_Chris
OK thanks
We're unable to book engineer visits at the moment due to a system issue but I'll let you know when I receive confirmation that the engineer visit has been booked
