Slow speed in the evening
32 REPLIES 32
For the last 3 days I've been getting very slow speeds in the evening.
In the morning it's fine and I get a ping of 20 and download speed of 25Mbps, but come the evening and my ping has gone up to 40 and my speed has dropped to 5Mbps,
This is both wireless and wired also I've tried 2 different routers and the same with both so not a router issue.
Could somebody look into this for me.
Hi garytastic,
I'm sorry to hear this and I'll take a look now. I've run a test on the line which hasn't detected a fault, however I can see re-connections on the line. Is the connection also dropping?
Could you run a few wired speed tests using the TalkTalk Speedtester when the speed is ok and also when the speed is  low. Can you also run a wired ping and trace route when the speed is good and when this drops and post the results into the thread.
Run a Ping or Traceroute
There are a few reconnections because I've installed a new router as my other one had issues, and it reconnected last night as it had updated the firmware.
Hi garytastic,
Ok thanks for confirming this. Once we have the speed test and pings and trace results then we can pass the slow speeds over to our Network Team for further investigation.
Have done the speed tests, ping and trace route as requested and here are the results, These are all wired results.
Pinging google.co.uk [216.58.198.163] with 32 bytes of data:
Reply from 216.58.198.163: bytes=32 time=41ms TTL=55
Reply from 216.58.198.163: bytes=32 time=58ms TTL=55
Reply from 216.58.198.163: bytes=32 time=36ms TTL=55
Reply from 216.58.198.163: bytes=32 time=34ms TTL=55
Ping statistics for 216.58.198.163:
Minimum = 34ms, Maximum = 58ms, Average = 42ms
racing route to google.co.uk [216.58.213.99]
over a maximum of 30 hops:
1 3 ms 1 ms 1 ms TALKTALK [192.168.1.1]
2 28 ms 29 ms 28 ms host-78-151-229-189.as13285.net [78.151.229.189]
3 37 ms 31 ms 30 ms host-78-151-229-188.as13285.net [78.151.229.188]
4 34 ms 34 ms 33 ms host-78-144-11-187.as13285.net [78.144.11.187]
5 34 ms 35 ms 38 ms 74.125.51.108
6 * * * Request timed out.
7 39 ms 39 ms 39 ms 172.253.68.210
8 37 ms 36 ms 35 ms 74.125.242.115
9 36 ms 35 ms 34 ms 216.239.58.131
10 37 ms 40 ms 36 ms 209.85.143.66
11 34 ms 32 ms 32 ms 108.170.246.161
12 35 ms 36 ms 36 ms 216.239.57.121
13 36 ms 34 ms 34 ms lhr25s02-in-f99.1e100.net [216.58.213.99]
Trace complete.
Pinging google.co.uk [172.217.169.3] with 32 bytes of data:
Reply from 172.217.169.3: bytes=32 time=36ms TTL=54
Ping statistics for 172.217.169.3:
Minimum = 36ms, Maximum = 36ms, Average = 36ms
Tracing route to google.co.uk [172.217.169.3]
1 <1 ms <1 ms <1 ms TALKTALK [192.168.1.1]
2 30 ms 30 ms 30 ms host-78-151-229-189.as13285.net [78.151.229.189]
3 30 ms 36 ms 32 ms host-78-151-229-188.as13285.net [78.151.229.188]
4 35 ms 35 ms 35 ms host-78-144-11-187.as13285.net [78.144.11.187]
5 36 ms 36 ms 35 ms 74.125.51.110
7 37 ms 38 ms 38 ms 172.253.66.100
8 36 ms 37 ms 36 ms 74.125.242.114
9 37 ms 37 ms 37 ms 209.85.250.185
10 37 ms 36 ms 36 ms 216.239.58.132
11 37 ms 37 ms 36 ms 108.170.246.129
12 37 ms 37 ms 37 ms 209.85.241.93
13 36 ms 36 ms 36 ms lhr25s26-in-f3.1e100.net [172.217.169.3]
Trace complete.
Pinging google.co.uk [216.58.213.99] with 32 bytes of data:
Reply from 216.58.213.99: bytes=32 time=20ms TTL=55
Ping statistics for 216.58.213.99:
Minimum = 20ms, Maximum = 20ms, Average = 20ms
Tracing route to google.co.uk [216.58.213.99]
2 14 ms 14 ms 14 ms host-78-151-229-189.as13285.net [78.151.229.189]
3 14 ms 14 ms 14 ms host-78-151-229-188.as13285.net [78.151.229.188]
4 20 ms 20 ms 19 ms host-78-144-11-187.as13285.net [78.144.11.187]
5 19 ms 19 ms 19 ms 74.125.51.108
7 21 ms 21 ms 21 ms 172.253.68.210
8 20 ms 20 ms 20 ms 74.125.242.115
9 21 ms 21 ms 21 ms 216.239.59.77
10 21 ms 22 ms 29 ms 216.239.58.132
11 21 ms 21 ms 21 ms 108.170.246.161
12 20 ms 20 ms 20 ms 216.239.57.121
13 20 ms 20 ms 20 ms lhr25s02-in-f3.1e100.net [216.58.213.99]
Trace complete.
Reply from 216.58.198.163: bytes=32 time=35ms TTL=55
Minimum = 35ms, Maximum = 36ms, Average = 35ms
Tracing route to google.co.uk [216.58.198.163]
2 31 ms 30 ms 30 ms host-78-151-229-189.as13285.net [78.151.229.189]
3 30 ms 30 ms 30 ms host-78-151-229-192.as13285.net [78.151.229.192]
4 45 ms 35 ms 36 ms host-78-144-11-37.as13285.net [78.144.11.37]
5 36 ms 35 ms 35 ms 72.14.208.22
7 38 ms 38 ms 38 ms 172.253.68.214
8 37 ms 37 ms 36 ms 74.125.242.114
9 38 ms 37 ms 38 ms 209.85.250.185
10 37 ms 36 ms 37 ms 216.239.58.132
11 37 ms 37 ms 37 ms 108.170.246.161
12 37 ms 36 ms 37 ms 108.170.232.99
13 36 ms 36 ms 36 ms lhr25s10-in-f3.1e100.net [216.58.198.163]
Trace complete.
Reply from 216.58.213.99: bytes=32 time=34ms TTL=55
Reply from 216.58.213.99: bytes=32 time=35ms TTL=55
Minimum = 34ms, Maximum = 35ms, Average = 34ms
2 29 ms 29 ms 30 ms host-78-151-229-189.as13285.net [78.151.229.189]
3 25 ms 25 ms 24 ms host-78-151-229-188.as13285.net [78.151.229.188]
4 26 ms 25 ms 26 ms host-78-144-11-187.as13285.net [78.144.11.187]
5 35 ms 33 ms 30 ms 74.125.51.108
7 36 ms 36 ms 35 ms 172.253.68.210
8 31 ms 32 ms 34 ms 74.125.242.115
9 37 ms 37 ms 35 ms 216.239.58.131
10 35 ms 35 ms 36 ms 209.85.143.66
11 31 ms 31 ms 31 ms 108.170.246.161
12 35 ms 35 ms 35 ms 216.239.57.121
13 34 ms 35 ms 34 ms lhr25s02-in-f3.1e100.net [216.58.213.99]
Trace complete.
Pinging google.co.uk [216.58.206.131] with 32 bytes of data:
Reply from 216.58.206.131: bytes=32 time=36ms TTL=54
Ping statistics for 216.58.206.131:
Tracing route to google.co.uk [216.58.206.99]
2 30 ms 31 ms 31 ms host-78-151-229-189.as13285.net [78.151.229.189]
3 31 ms 31 ms 31 ms host-78-151-229-192.as13285.net [78.151.229.192]
4 36 ms 36 ms * host-78-144-11-37.as13285.net [78.144.11.37]
5 35 ms 36 ms 36 ms 72.14.208.22
7 37 ms 37 ms 36 ms 108.170.238.118
8 36 ms 36 ms 35 ms 216.239.58.223
9 36 ms 35 ms 35 ms lhr25s14-in-f3.1e100.net [216.58.206.99]
Trace complete.
I hope that's enough information for you to find out what the issue is.
Hi garytastic,
Thanks for running these tests. I've passed the slow throughput speeds of an evening over to our Network Team now and I'll let you know as soon as I receive an update back.
Hi, any update?
I have spoken to others who are on Talk talk but on different exchanges who are experiencing the same issue.
Hi garytastic,
I'm still looking into this with our Network Team. Could I just confirm, are the others who are experiencing the same issue around the same area as yourself?
Hi the others I spoke to are between 3-5 miles away.
Hi garytastic,
I've received an update to advise that one of the line tests have detected a potential fault so if all testing has been completed then the next step would be to arrange an engineer visit to investigate further. This would be to look into the overall speed of the connection.
In regards to the slow speeds of an evening could I just confirm, is the throughput speed low if you run the speed test with only the one device connected to the line?
I can confirm that when I did the speed tests there was only one device connected. And this was a wired connection.
As you can see on your traceroute, hop 6 times out every time, this is an IP to IP routing error on the back-haul.
IT IS NOT A FAULT as claimed by TT staff - IT IS A ROUTING ERROR in a data centre!
BT always used to do the same thing, when it was a routing error they would claim a fault on the line, you'll just have to wait it out till someone in the data centre fixes the routing issue
Hi garytastic,
Thanks for confirming this. I am still looking into this and I'll let you know as soon as I know more.
Hi garytastic,
Our Network Team have been unable to find any Network issues and we also can't see any sign of congestion of an evening so the next step will be to arrange an engineer visit to investigate further so I'm just sending you a Personal Message to confirm some details.
Please do not post any personal information on the Community, reply via Personal Message (PM) only.
Hi, the last 2 evenings my speeds have been back to normal so was there a local fault that has now been fixed?
Hi garytastic,
Thanks for the update. Not that I'm aware, the last update from our Network Team advised that following their investigation they had been unable to identify any issues at peak times. Could you monitor the connection over the next few evenings and let us know how this compares now?
Yes I will monitor it for the next few days. I don't want to have to take time off from work for an engineer visit if there isn't a fault.
Hi garytastic,
Ok, no I understand. Please let us know 🙂
Thanks. I will post back on here if this issue returns.
