Slow speed
19 REPLIES 19
Chat Champion
Can someone.check my speed please it keeps going slow
Hi Safc10boxer12,
Line test is passing and router is in sync at 33.0Mbps. Your line profile isn't capping your speed so could you try switching your router off for 30 minutes then switch back on and retest
Chat Champion
IV done that and it's at 31 now
OK thanks - is your router currently connected to your test socket?
Chat Champion
No just in the normal socket
OK thanks - how many telephone sockets do you have? Do you have anything connected to your telephone socket(s) in addition to your router?
Chat Champion
1 socket and nothing apart from router
Could you connect your router to the test socket with a micro-filter and check to see if the speed improves, just to rule out any issues with the master socket faceplate
Chat Champion
IV done that now
OK thanks, I'll run a line test now and get back to you
Chat Champion
Line test is passing still but sync speed is virtually the same at 33.4Mbps. So you've just got the router connected to the test socket via a micro-filter, no other device connected to the micro-filter?
Chat Champion
Sorry I did pull the devices I will do it now
  Thanks, I'll run the test again now
Still 33.4Mbps, everything still unplugged except you router?
Chat Champion
Yeah just the power is plugged in and the router is flashing orange
Sorry, just to confirm, is the router connected to the test socket at the moment? If it is, is the light still flashing orange?
Chat Champion
Sorry I had to go out are you still available or will just wait until tomorrow
Chat Champion
Morning
Would you like me to take everything again
Chat Champion
Is there anyone there to help please
