Slow speeds
44 REPLIES 44
Safc10boxer12
Can someone check my line please speed tests are only giving me 25mbps at best
Hi Safc10boxer12,
I've run a test on the line which hasn't detected a fault. Just to confirm, what speeds were you previously receiving? Are you also running the speed tests wired or wireless?
Safc10boxer12
Morning
I was always getting over 30 but I was sent a new hub and getting 25 I'm running the tests wired
Hi Safc10boxer12
Speeds can vary slightly between different routers. How long has the new router been connected for?
Safc10boxer12
A few weeks now
Hi Safc10boxer12,
Ok thanks for confirming this. What was the make and model of the previous router? Do you still have this router?
Safc10boxer12
It was a talk talk super router I don't know the model number sorry... I had to send the router back
Hi Safc10boxer12,
How many telephone sockets do you have? What other devices do you have connected in addition to your router?
Does your master socket have a Test Socket?
Safc10boxer12
One telephone socket
4 devices plugged in the back of the router
Yes I have a test socket
Hi Safc10boxer12,
Would it be possible to connect the router at the test socket for at least 48hrs to see if DLM increases the sync speed?
Safc10boxer12
Ok will do
Hi Safc10boxer12,
Thanks, please can you bump your thread on Monday and we can re-check the connection stats again.
Safc10boxer12
I'm unable to do it as when I put it in the test socket it's knocking the internet off
Hi Safc10boxer12
Just to confirm, when you connect the filter and router at the test socket does the connection start to drop out?
Safc10boxer12
I have pre-figured master socket so I don't need filters do I ?
Hi Safc10boxer12
Are you able to remove the face plate so you can connect at the test socket? (just for testing purposes)
Safc10boxer12
Yeah I can do that but when I plug it in I lose connection
Hi Safc10boxer12
Have you tested with a different microfilter at the test socket?
Would it be possible to post a photo of your master socket when the router is connected at the test socket?
Safc10boxer12
I don't have any micro filters I said them all back when I sent the router back I didn't think I needed them sorry
Hi Safc10boxer12
I can send a replacement microfilter would you like me to arrange this?
