Slow speeds
Safc10boxer12
Yes please of you think it will help
This has been ordered and is on the way.
Safc10boxer12
Thank you
Safc10boxer12
IV received the filter should I put it into the test socket
Hi Safc10boxer12
Yes please can you connect the router and phone directly at the test socket using the microfilter.
Safc10boxer12
Done
Hi Safc10boxer12
Thank you. Would it be possible to leave the router connected in this set up for at least 48hrs whilst DLM is monitoring the connection?
Safc10boxer12
Will do
Hi Safc10boxer12
Thank you, we can then check the sync speed again to see if DLM has made any changes.
Safc10boxer12
Hi.
How's it going ?
Hi Safc10boxer12,
Could you just switch your router off for 30 minutes then switch back on and check if speed improves, if it doesn't then I'll ask our network team to take a look at this for you
Safc10boxer12
Done
Hi Safc10boxer12,
Thanks. Could you run a wired speed test please using the TalkTalk Speed Tester so we can see your current throughput speeds.
Safc10boxer12
Safc10boxer12
Hi Safc10boxer12
I have passed this over to our Network Team for investigation and I will post back on this thread as soon as I receive further information.
Hi Safc10boxer12
The next step will be to arrange an Openreach engineer visit.
Hi Safc10boxer12
I have replied to your Private Message.
Hi Safc10boxer12,
How are you getting on?
