Can anybody reassure me that the eventual arrival of the new hub will help with my appalling speeds !!?? ( have wrongly received a WiFi extender kit today ) my average download speed is 5.5 Mbps and download 2.5 Mbps. It’s so frustrating as I am on faster fibre ! Is there a minimum I should be getting !!???
Can you please add your home phone number to your Community Profile so I can locate your details.
If unsure of your number, simply dial 17070 from your land line phone and this will confirm the number for you.
Please reply when this has been updated.
Hi Dsparks,
Thanks. I've run a test on the line which hasn't detected a fault, however I can see quite a few re-connections on the line. Are you experiencing any issues with the voice service such as noise on the line? Does your master socket have a test socket?
Good morning Michelle !
There have been no noise issues. Yes, there is a test socket, I have just plugged into it. Sadly no change in speeds =[
Hi Dsparks,
Thanks for the update. Is the router still connected to the test socket at the moment? Was the connection also unstable when the router was connected to the test socket? It can take DLM between 24-48hrs to make changes to the sync speed if the connection remains stable.
Hello !
I have received my new WiFi hub and it is connected to the master socket, not test. Speeds are still the same :/.
When my previous router was connected to the test socket there was no change in speeds =[
where do I possibly go from here ????
Hi Dsparks
Would it be possible to connect the new router at the test socket just to see if DLM starts to increase the speed with the new router?
Hi Dsparks
Thank you, we advise to allow DLM up to 48hrs to monitor the connection and start making changes to the line profile.
We can check the connection stats again in 48hrs to see if DLM has made any changes.
Hi Dsparks
Ok, I've asked our Network Team to take a look at this and I will post back on this thread as soon as I receive further information.
Hi Dsparks
Some good news !!! Engineer has been and replaced the master socket, although things will fluctuate initially due to line reset. Am now showing speeds of 24&8. Now to keep my fingers crossed =]
Hi Dsparks
Thanks for keeping us updated. Please can you continue to monitor the connection and let us know how you get on.
Debbie 🙂
