Slow speeds
4 REPLIES 4
Noticed our speeds plummeting lately - in the evenings from about 5. Typically we get about 60ish Mbps with really low latency. We're now at something 2-4 with latency from 100-300. The talk talk tool reports is at 40, but Ookla, Google and various others are giving much, much lower numbers. Can't think the contention ratio in our area has increased as it's all old housing hooked up to the exchange. This feels like throttling - I've been working from home a lot lately so the issues been really noticeable.
What is your router's downstream line rate and were these speed tests done on wired or wireless connections? Are wired better than wireless?
Router downstream is generally around 80 ish. Tests conducted wired and wirelessly. It certainly feels like some sort of peak time throttling or traffic shaping and what's more odd is the discrepancy between talktalks speed test and Ookla/Google. Would assume that any shaping is bypassed when using their sponsored/embedded speed test.
If it continues I'll get the work laptop hooked up to the router and run some more thorough tests with that.
Be interesting to see if it suddenly stops at the end of the month - maybe the unlimited isn't as unlimited as they say.
Hi Mattcart81
I've completed a line test which hasn't detected any faults and the sync speed looks good.
Please can you run some speed tests when the speed is ok and some more speed tests when the speed drops using the TT speed tester so we can see the results?
Have you also run the speed tests wired and using a different device?
