Slower Internet than I used to get on a cheaper Package
6 REPLIES 6
Bblueroom
I used to have a package where the maximum download was something like 50 megabits /s and i would consistently get 40 to 45 megabits /s which i was very happy with. Then around June 2018 i heard there was a new package which would take my maximum to 67 megabits, it also meant i had to get a boost which was an extra £5 per month. Either way i went for it as I wanted this 60+megabit /s, i realised right away that it was not as good as before as i was getting around 30 megabits /s ,but i dealt with it. however now that i have renewed my contract I would like to get this sorted, while speaking to someone on the phone i mentioned that my broadband was slower than i would like so they did a check and said everything was fine so i also mentioned that my router was 1 or 2 generations old. Sadly that didn't offer to replace it, so over the weekend i have purchased a high end router to see if that made a slight improvement but it has not. I highest receive is 37.2 megabits and that's if i am standing right next to the router with WiFi or connected by Ethernet. I believe my minimum is 36.8 megabits /s or something similar which i am getting below all the time
Any help would be great appreciated
Susan
Have you turned your router off for a minimum of 30 minutes, otherwise it will not pick up the faster speed?
Bblueroom
Hi Keith,
I did not turn the router off for at least 30 mins, so I left it switched off over night and this morning I am still getting the same readings. Would say that It could be my open reach modem as its quite old but I have gotten 45+ megabits in the past so I should at least see same speeds.
Thanks for your suggestion
Susan
No problem Susan, I have asked one of TalkTalk's OCEs to pick your thread up and investigate it for you.
Hi Susan
I've completed a line test which hasn't detected any faults and your line is in sync at 40mb.
Please can you power down the router for a full 30 minutes and then leave the router connected at the test socket for 48hrs (without rebooting the router) We can check the connection stats again on Wednesday to see if DLM has made any changes to the line profile/speed.
Bblueroom
Hi Debbie,
Sorry for late reply i have been rather busy this week. I am happier at the fact the internet has been more consistent after I changed the router and I getting better readings even in areas of the house far from my router (still between 30-37 at most). I did what you said and have not rebooted the router since your reply.
Is there anything that can be done to increase the sync higher, since the limit is 68mb. Or is a case that the highest my house can get is 40mb, even though I used to get around 45mb
thanks
Susan
Hi Susan
I've checked the connection stats and your line is in sync at 40mb.
Please can you power down your router for a full 30 minutes and then post back on this thread so we can check this again.
