Slower speed than the WIfi Hub suggests I should have
Hi Rob,
Thanks for the bump. There's no update yet so I'm chasing this up for you. If you don't hear anything later today can you bump the thread again tomorrow.
Hi Rob,
Our network team have said they'll need to arrange an engineer visit to investigate further. if you'd like us to arrange the engineer visit can you confirm:
I've also PM'd you to confirm some other details
Hey Chris,
I'm not the account holder so I will have to pass the message on, but I know I'll be asked which of the possible charges would apply to us? I assume it's just the section listed Fibre Service Visit? Or would other subsections apply too?
Cheers,
Rob
Hi Rob,
If you could just ask the account holder to register on the Community and post on the thread we can then confirm the details with them. The potential charges are under Openreach engineer visit
Hello Chris,
I'm the account holder.
Regards, Franco
Hi Franco,
Thanks for registering on the Community
Can you please complete your Community Profile and if you'd like us to go ahead and arrange the engineer visit can you please confirm:
Hi chris,
i accept the charges, afternoon slot would be better, any day but thursday should be fine.  I assume i personally do not need to be there, just someone in the house?
regards, franco.
Hi Franco,
Thanks for the PM, I've replied requesting a bit more information
Hi Franco,
Apologies, please ignore my PM earlier today, I can see that you're provided the information I requested (no you personally don't have to be there)
Hi Franco,
Our network team have confirmed that the engineer visit is booked for 29/01/2019 PM (13:00-18:00) - please let us know how you get on
Hey Chris,
Engineer just left. He fiddled/changed/magicked the first box into the house - not the master socket - as there was corrosion on the contacts and put a new filtered faceplate on the master socket too. SNR reported by his terminal went from ~ 4db to ~8db downstream. The terminal reported max capable sync rate as ~56/12Mbps.
Connected the WiFi hub back up and removed the hg635, it's synced at ~40/10 with a max showing of ~45/10, can't tell the SNR because the Hub doesn't report it correctly.
Hopefully this'll solve the issue, the engineer seems to think it was more than likely the first box. Fingers crossed!
Cheers,
Rob
Hi Rob,
Thanks for the update, if you do experience any further problems just let us know
