Smart TV won't connect to internet
16 REPLIES 16
Have a new Philips Smart TV which we're trying to connect to internet. Attaches to TalkTalk router OK using Wifi, TPLink or cable direct into router. Can see it from router software. Won't go out to internet though. If we run Youtube we just get the message 'Unable to load requested page'. Any suggestions?
Hi cazhughes
Are all other devices connected and working ok? Which router are you using? (make and model)
Hi Debbie
Thanks for getting back to us. We have a Huawei HG633 Router with a WD MyCloud connected by LAN cable (have switched this off for testing, just in case) and a TP-Link to TP-Link connection for TalkTalk box with Panasonic TV connected. Soundbase and HiFi use Wireless but have been switched off while attempting to connect new Philips TV. This needs Wireless in location but have also tested with TP-Link and LAN cable. All existing devices work OK.
Regards ..... Caz
What do the TV diagnostics say ?
i.e. (Remote) Home button -> Settings -> Wireless and networks ->
Connect to network
Check the network
View network settings
etc
etc
Ideally it needs a static IP and unique network name.
Note: It connects either via WiFi or ethernet cable, not both at the same time.
I'm just a customer who might be able to help, not official help & support.
Hi Piethorne
Settings and messages as follows -
Connect to Network -
Internet connection not available. Check your router settings or contact your ISP.
Check Network -
The TV is connected to your router, and the router is connected to the internet.
View network -
Network type - Wireless
Status - Connected
Network - TALKTALK92407E
Speed - 130 Mbps
Signal strength - Full
Encryption method - WPA2-PSK
Network mode - DHCP
IP address - 192.168.1.11
Netmask - 255.255.255.0
Gateway - 192.168.1.1
DNS 1 - 192.168.1.1
DNS 2 - 192.168.1.1
Network configuration - DHCP
So, DHCP rather than static IP. Network name is TV model. And, yes, I know that it's either WifI or ethernet cable, not both at the same time. We tried cable and TP-Link only after WiFi had failed.
Cheers .... Caz
Hi caz,
Can I just confirm, has this previously connected and worked ok? Do any of the players load?
The settings are similar to mine for a wireless connection, except for the primary and secondary DNS addresses. (I've set the router DHCP DNS server to use googles servers - primary 8.8.8.8 and secondary 8.8.4.4)
If I remember correctly, I had a similar issue at first (Philips 4k 43PUS6754) with internet apps not working and did a factory reset of the TV (only takes a minute). After that there was no problem connecting either a wired or wirelessly.
Hi Michelle
This is a new TV so not worked before. Different apps do different things -
iPlayer, SmartTV and Internet Browser go nowhere.
Youtube says 'Unable to load requested page'.
All4 shows all the adverts then says 'This content is currently unavailable' (!)
My5 says 'Currently unavailable due to a technical problem'.
ITV Hub alone seems to work OK.
Regards .... Caz
Tried a reset but made no difference.
I can't see how to amend DNS settings in router interface.
Cheers
Can you reboot the router and I'll see if I can check the settings remotely.
Router has been rebooted.
I've separated the wifi channels, so when connecting to wifi, you will see 2 wifi options, both with the same name, except the 5Ghz wifi now ends with '5'.
I've also changed the DNS.
If you can try and connect the TV, see if it will connect to either of the wifi channels and see if it will work.
If this fails, then we can try a different model router.
Karl - Have tried TALKTALK92407E again (assume password not changed) and has made no difference. TALKTALK924075 is not visible on TV even after a rescan.
I'll get a new router out to you (different model) and see if that is better.
 Hi Karl
Got new router this afternoon - very quick! All connected and now working OK. Thanks so much for your help.
Regards .... Caz
Hi Caz,
Thanks for the update 🙂
