Software update request
6 REPLIES 6
Enlightened One
According to : https://www.talktalk.co.uk/help/servicestatus/?communityfooter=true
"You have a Huawei-HG635 but the software needs updating to the latest version."
Could my firmware please be updated ?
At the moment - it is on v1.10t
Do you have remote updates and TR-069 enabled?
Enlightened One
What is TR-069 ?
I would say "No"
I have remote management enabled - now !
I am sure that my router firmware was updated a couple of years ago - by your goodselves ..... ?
OK, it should update automatically. If you have adjusted any settings to prevent remote access this will not have happened.
Try a pinhole reset and leave it overnight. If it hasn't updated by tomorrow let us know and I will gladly flag it up to the OCE for you.
Hi Weevie,
Has your routers firmware now updates (I can't communicate with your router at the moment)?
Enlightened One
No it hasn't
It should be accessible to you
Hi Weevie
Your router firmware has been been updated.
