Hi all,
My DSL-3782 super router displays a solid red power light.
I have tried the turning off, waiting 15 minutes and turning back on. I have also tried resetting the router by holding the reset button for 5 seconds.
It's been a couple of days now. I have tried this a few times but the router is a solid red power light every single time it powers back on.
I believe the router might be faulty. Is anyone able to assist on this issue?
It is definitely faulty. I have asked one of TalkTalk's OCEs to pick your thread up and investigate it for you.
Hi Smcalister
Please can you add your TalkTalk telephone number to your Community Profile, we can then look into this further.
Hi Smcalister
I've completed a line test which hasn't detected any faults.
Can I just check if your landline service is working ok when making calls?
I can send a replacement router for testing, would you like me to arrange this?
Hi Debbie, a replacement router would be ideal.
Nothing has changed in my office set up, except the only light which shows on the router is the power light, which is a solid permanent red at all times.
Hi Smcalister
Please can you send me a Private Message to confirm the name on the account, I can then send the replacement router.
Hi Smcalister
Thanks for the Private Message.
