Speed Checker
6 REPLIES 6
phillip151
I've just run your speed checker and it doesn't finish. go beyond sted 3.
Patricia55
Whizz Kid
Hi, @phillip151
I've been having the same problem with my Speed Checker for ages, so let's hope TT can fix it.
I've learnt a lot about TT since joining the forum on 30/12/18..........I say no more.
I8this
TalkTalk,s speed checker has not worked properly since they came back online after that major hack of their system 3 years ago, try this one:-
Internet Speedtest
If it does not work the 1st time just click 'retry'
If case you have forgotten the Do’s and Don’ts. There are members that have. Remember:-Be yourself and tell it like it is,. Be courteous to other customers. Give others the benefit of the doubt. Update your community profile. The Forum Guidelines apply to ALL members there are/should be, NO exceptions.
phillip151
Thanks Smiley_Face I try other speed checkers but I wanted to use the Talk Talk one just in case my speeds get logged.
That link which @I8this  gave you is a shortcut to the TalkTalk checker, if you want your results logged against your account enter your full phone number where indicated.
phillip151
There is no option to enter my phone number, even though I am already logged in to Talk Talk.
phillip151
I'm blind, I had to scroll down and there it is to enter my number. Doh!
