Speed Up and Down
6 REPLIES 6
winchesterox
Hi Community
My first post.
About 3 days ago I noticed that the speed was woeful (even dropping to 0.0mbps) and I contacted Technical Help through the chat function - using cell data. Technical Help remotely ran diagnostics on the router and updated the software. They also advised that NGA and TAM would be run and that I should respond if I continued to have problems.
Well I immediately got an improvement and speeds went up to around 20 mbps (the best I am able to get on Superfast Fibre), but last night it started to drop out a bit (websites freezing etc.) and I wondered whether the old problem was back. I have started running a continual speed test and the average appears to be around 10 mbps dropping down to around 500kbps sometimes.
Is it normal for speeds to be so up and down?
Andy
Andy S
Skynet_TX
Hi @winchesterox,
Speeds should not vary that much, it can be normal for speeds to dip a little at peak times, but you should not see variation that extreme.
It would be worth going to the Service Centre to do a test on your phone line, this will indicate if there is currently a fault on your line. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
The staff here won't be around now until Monday, but they should be able to respond to this post early next week to help.
OCE_Chris
Hi Andy,
if you still need assistance can you please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
winchesterox
Hi Chris
Done
Andy
Andy S
OCE_Michelle
Hi Andy,
Thank you. I've run a test on the line which hasn't detected a fault. Can I just confirm, when you speeds are dropping very low are you connected wired or wireless? Does this only seem to happen of an evening or at any time of the day? Do you have any devices connected wired to see how the speeds compare?
winchesterox
Hi Michelle,
When speeds drop really low I am on wireless. I've not yet tried going wired.
I have noticed that around 9 pm can be a point of low speed, although continuous speed test indicates a really low drop at 1330 and 1500 today.
Does this help?
Andy
Andy S
OCE_Michelle
Hi Andy,
Thanks for confirming. Would it be possible to test wired just so we can confirm if this is related to the wireless? We can then offer some additional advice for the wireless speeds.
