Speed boost below minimum speed
It's plugged into the test socket through a microfilter now.
Hi Daniel,
Thanks for confirming this. Could you please bump your thread (request an update) on Wednesday and we can re-check the connection stats again to see if DLM has made any changes to the sync speed.
Hi. I've left the router connected to the test socket since Monday.
Hi Daniel1900,
What do you currently have connected to your test socket? Do you have another router you can test with?
It's a TalkTalk Super Router (Huawei HG633) connected to the test socket. Yes I have another router that's not in use at the moment.
Hi Daniel1900,
Is the other router one that we supplied? Is it fibre compatible? If it is could you please connect it to your test socket and leave it there for the time being and we'll see if there's any speed improvement
It's a TalkTalk Plus Fibre router (HG533). I'll connect it to the test socket just now.
I tried it with the Plus Fibre router and set it up in the same way as the Super Router, but there's no internet access on it at all. I ended up having to set the Super Router back up to get internet access back. Is there any other way forward?
Hi Daniel1900,
The HG533 unfortunately will only work with fibre if connected via a fibre modem. I can send another router to test with, would you like me to arrange this?
Yes please.
A router is on the way to you.
The Wi-Fi Hub router has been set up and connected to the test socket since Saturday afternoon.
Hi Daniel1900,
Thanks for trying that. As the current sync speed is just below the guaranteed minimum we can log this out for engineer visit. If you'd like us to arrange this please let us know and we'll confirmed some details with you
Yes I would like to arrange an engineer visit.
Hi Daniel,
If you'd like us to arrange the engineer visit can you confirm:
I've also sent you a PM to confirm some details
Yes I accept potential Engineers charges. I will be in between 1pm and 6pm except for Monday and Thursday.
Hi Daniel1900,
Thanks for the PM, I've replied requesting a bit more information
I've replied to the PM with more information.
Hi Daniel
Thanks for the PM. I've provisionally booked the appointment for Tuesday 3rd PM (13:00 - 18:00) - please let us know how you get on
Okay thank you. I'll post again after the engineer visit.
