Speed boost is slow!
7 REPLIES 7
Vickyfluff
Visitor
I had fibre at 37mb download, added speed boost but the speed is the same. It's on the new wifi hub. Tried 7 times with online chat to no avail as it kept disconnecting, each time going through the same cycle. Only one phone connection and it's all on the master socket. Please help!
Vickyfluff
Visitor
Line 1
Downstream Upstream
Actual Rate [Kbps] 32400 9998
Maximum Rate [Kbps] 43830 9998
Noise Margin [dB] 10.40 9.70
Attenuation [dB] 15.90 0.00
Power [dBm] 12.60 6.80
Hi @Vickyfluff
Thanks for your post
I have found a slight problem, which meant the speed boost didnt apply properly, So I have fixed that issue,
Your speeds should increase in the next few hours
Vickyfluff
Visitor
Hi OCE_Arne
Wow, it that works thank you ever so much. I really appreciate your looking into this.
I will update in a few hours.
Thank you again
Vickyfluff
Visitor
HI @OCE_Arne,
Do I need to do anything special like restart the hub or is it best to just leave it alone to do its thing?
If the speeds havnt improved in a few hours leave the hub powered off for 30 mins.
Vickyfluff
Visitor
I have left it a few hours and also turned off for 30 minutes (turned back on just now) and everything seems the same, no faster or slower ( thankfully). Do i need to wait longer ?
hosay299
Insightful One
@Vickyfluff  see how it is over the week end do not turn the router off unless told to by the oce on here
as each time u do it can not help as the fibre side has a auto profile
might find better tomorrow might be just taking some time to go through the system
Oce will reply next week now they do not work weekends
Hope that help Joe R If so then give me a Kudos ( Click the Thumb up Button)
