i got a new New router Archer VR400 for about 3 months and speed has been stable for 2 of them
Now My speed is dropping same as before i had a new bt socket fitted by open reach and fixed corroded wires open reach engineer said if it does not fix it he would have to try a different fix
When i got my new router my sync speed went to 27439 kbps with a speed test of 25mbps
Then sync speed 25864kbps with a speed test of 23mbps
And now sync speed 22399kbps with a speed test of 21mbps
4k youtube videos at 60fps are constantly buffering yet again
And what makes me more mad i am on the 38mbps package and paying the same amount
as the people who get close to the full speed of 38mbps when i am only getting 21mbps
this is not right
what will be done about this
thank you
just done a reboot
max rate gone up to 33925kbps
but current speed still the same 22399kbps
thank you
The SNR keeps dropping on its self my modem cannot manipulate the snr
screenshot this morning
my speed has dropped 3 times since it was fix by openreach this is a ongoing problem for years
my dl was 33mbps when i first got fiber and i know how length of the copper line
Why does my SNR on download keep dropping? it goes up after a reboot then keeps dropping to about 1 then the line drops then my speed drops after the line comes back up
thanks
Hi Not-Happy
I've completed a line test which hasn't detected any faults and your line is in sync at 22.4mb.
Is your router connected at the test socket? Do you also experience the drop in speed if you connect wired?
How often do you reboot the router as this can affect the sync speed?
Hi Debbie
its been fine for months after openreach fix it
No i have only rebooted my router twice after my speed dropped to 21mbps on speed test
the first time i turned it off about 1 hour last week then rebooted my router via the reboot button days after
the dsl has droped 3 times in just over a month and my speed has dropped 3 times too as shows by the screen shots in first post
i also appear to be getting lots of errors
I don't have it plugged in to test socket. The socked is a new one installed by openreach about 7 months ago to fix the corroded wires its a master socket C5 it has no screws on it does it even have a test socket
i always do speed tests with a wired connection
Thank you
Hi Not-Happy
Does your master socket have 2 clips on either side of the socket so the face plate can be removed?
Hi Debbie
Thank you yes the master socket does have 2 clips on either side you push in silly me
So i have plugged it into the test socket this morning
before test socket
after test socket
the dl speed is the same
and still lots of errors.
Thank you
Hi Not-Happy
Would it be possible to leave the router at the test socket for 48hrs whilst DLM is monitoring the connection in this set up?
Hi Debbie
Yes i can leave router at the test socket for 48hrs
will post back after.
Thank you
Hi Not-Happy
Thank you, we can then check the sync speed again to see if DLM has made any changes.
Hi Debbie
NOT HAPPY NOW FIX MY SPEEDS LATER
JUST GOT A PHONE CALL FROM 0188054444 SOUNDED LIKE FROM INDIA
SAYING MY ROUTER IS SENDING ERRORS AND WARNINGS
He had my name account number and my postcode all correct the just proves that something
dogey is going on with sh#t talk
then i was called stupid i don't know anything
WHY IS THIS ??????????
this best get looked in to
THIS IS EVERY TIME I REPORT A PROBLEM CALLS FROM SCAMMERS
WHY ??????
Hi Not-Happy
Have you reported this call using Check and Report
I can raise a complaint so this can be discussed with a complaints manager. Would you like me to arrange this?
Hi Debbie
sorry for the anger it is not at you or any staff here you all do a good job.
Will the complaints manager be a call from the (scum) call centre in India if so NO
how will i know it's from Talktalk the amount of SCAM calls i have had from so called TT is unreal all from India ?
I live in the uk i should not have to deal with overseas call centrers i can not understand and get flobed off with BS that is read from a script😡
Reporting to ofcom my be a better option ?
THESE CALL CENTERS IN INDIA THAT TALKTALK ARE USING ARE 100% SELLING CUSTOMER DATA😠😠😡😡
There is no other way they have all my details
This has happen more than 3 times now after reporting a problem 1st time could be a coincidence not the 2nd & 3rd and this is the first time they have all my details.
OR TT HAS BEEN HACKED AGAIN HAS IT ?
HOW DOES HE HAVE ALL MY DETAILS ? I WANT ANSWERS ?
And my dl speed is no better will post screen shot later
Thank you
Hi Not-Happy,
As OCE_Debbie mentioned, could you report the number through Check and Report. Please also see our CallSafe feature, this screens every call to your phone and helps stop unwanted callers reaching you.
We can raise the complaint to our CEO's Office. If you'd like us to arrange this please let us know
Hi Chris
You say
I HAVE DONE THIS IT'S THE FIRST THING I DID
STOPPING THE CALLS IS ONE THING BUT WHEN THEY HAVE ALL MY INFO FROM SOMEWHERE THAT'S A ISSUE TO ME AND THIS DOES NOT ANSWER MY QUESTION HOW THEY HAVE ALL MY DETAILS ?
THIS IS A BIG PROBLEM TO ME AND I AM SURE IT WOULD BE A PROBLEM TO YOU ALSO AND ANYONE ELSE
AGAIN MY QUESTION HAS NOT BEEN ANSWERED HOW WILL I KNOW ITS A CALL FROM TT I DON'T TRUST ANY CALL NOW FROM INDIA AND MORE THAN LIKELY THE CALL WILL BE FROM SCAM COUNTRY
AND I WILL SAY AGAIN THESE CALL CENTERS IN INDIA THAT TALKTALK ARE USING ARE 100% SELLING CUSTOMER DATA
PLEASE ANSWER THE ASKED QUESTIONS?
NOT AVOID THEM
I AM NOT HAPPY
THANK YOU
Hi Not-Happy
If we escalate this over to our CEO's Office then I can ask the Complaints Manager to contact you by email first if you would prefer?
Hi Debbie
Yes i would prefer this that would be better as i don't know who is tt or not on the phone
that much scam calls
Can i now get back to my speed issue please?
Thank You
Could you PM me with the email address that you would like our Complaint Manager to contact you on, and we'll arrange this for you (please don't post this on the open forum)
