Speedtest High but downloads low with perfect signal
14 REPLIES 14
I have never had any issues with by talk talk fibre package. Speedtest is always between 50-60mb.
However over recent times Ive had very slow download speeds on my desktop pc and other devices. inc firesticks.
I have ran speedtest and ranges from between 0.6mb to 2mb on firestick which as i stream alot causing huge buffering issues. Desktop download speed is very slow 0.6-0.9mb.
My devices have excellent signal and tested via my mobile phone speed test too.
Am I being throttled back
I expected to find speedtest speeds to be very low and explain the issues however not the case.
Ive turned router off and on to reset a few times however the speed on my pc downloads and also my firestick streaming is painful in comparison to what it used to be. I havent made any changes
Hi @woodland81 welcome to the community your post has been flagged for assistance and you should hear during tomorrow.
I'm guessing you're connected with WiFi? If yes the cause of your problem might not even be in your home, interference coming from a neighbour could be a problem.
Initially I would suggest Split your router's SSID (wireless network name) to see if 2.4 or 5ghz has issues.
Yeah firesticks are connected via wifi but the desktop download is very slow and even when i had a few browsers open for streams, they were buffering, device manager was showing network usage was fluctuating between 15mb-20mb.
Even when speedtests were bringing back 60mb for wifi via phone and wired desktop
Firestick were getting 0.3mb last night
Hi @woodland81 did you already try splitting the phone ssid?
Hi woodland81
Sync speed looks ok however the line tests are failing on the Voice circuit and picking up a battery fault and possible disconnection fault.  These issues will have an impact on the Broadband and need to be addressed.
I've logged this out to BT Openreach for a Non Appointed engineer - Non appointed means the engineer will be dispatched to look at the line without requiring an appointment be made with you to visit your property.
Thankyou that is reassuring that an issue has been found and being dealt with.
It explains the good speed test but speed failure. no need to try the splitting (frequency channels)
No Problem 🙂
Check back tomorrow and I can review the engineer report and see what they find.
Any updates ? 😊
No notes as yet, the fault is still under investigation by BT.
Any update so far ? Ive not been home today to test it, i know it was still dodgy yesterday evening
Hi woodland81,
Sorry for the delay. I've checked and the latest update is that this fault was being investigated by an engineer late yesterday afternoon and is still being investigated at the moment.
all sorted?
I did have a couple of days where my internet would just disconnect all together
Hi woodland81
The Openreach engineer left notes to advise that the fault was resolved, fault was found on underground cable.
Are you still experiencing this fault?
i am getting a better speed now. But it is down to around 36mb on speedtests.
Previously 60+ as i was paying that Add-on to double my speed.
Will this return back up to 60?
Hi woodland81
Can I just check, have you powered down the router for a full 30 minutes and then run a speed test?
