Static IP address on new hub
4 REPLIES 4
I've just got a new wifi hub version SG4K10001400t - but I can't seem to find the static ip settings.
I *really* need to route my internal services to particulate ip addresses, but there seems to no option to set this in the gut for the router. The link http://192.168.1.1/0.1/gui/#/mybox/DHCP has no static ip settings listed.
How do a setup my internal network for this?
Help appreciated!
Hi @stevegal that version of firmware does not support static ip, later versions do. To solutions, either the OCE team will pick up your post and push it out to you or you could try rebooting your router and see what happens overnight. Either way it should be fine tomorrow.
Hi stevegal
The firmware will usually update overnight - has your router firmware now updated to 2808t ?
This is now available. Thanks! And the firmware has updated to 2808t
Excellent, thanks for letting me know.
