I have the Huawei HG633 router that I was supplied with when I signed up for TalkTalk, it even has the TalkTalk logo stamped on it. Why can't the status page identify a router YOU supplied?
I was away for over a month and on my return it took 3 days for the "system" to recognise my router, which is also a HG633.
Has you router also been switched off for a while ?
Hi Tryst46
Please can you factory reset your router using the pin hole reset for ten seconds? I can then try and connect to your router.
Hi Tryst46
