Super Fast Boost
Have sent you a copy of renewal for 25.95 a month for broadband and speedboost. Thanks
Hi. Yes the other boosts are correct. Thanks for you help.
Hi. Speed has not increased yet and do you have any update on getting the correct price applied to my account. Thanks
Hi @mark17
Sorry for the delay we are still working on the price side of things.
What speeds are you seeing at your side ?
Thanks for reply. Have just checked and router now syncs at 40.3. Has always been 39 before. If you could advise about price when it is sorted I would be most grateful. Thanks for your help.
Hi Mark.
It looks like Package price has now been updated to £22.95 + £3 for the boost.
Is the Broadband speed still an issue?
Hi. My router syncs at 48 and download speedtest is about 44mbps. Upload speed is the same as always had which is 9mbps. Thanks for all your help.
Can you switch the router off for at least 20 mins then reboot and re-test.
Emma
Be sure to give kudos and accept your solution
