Super Slow speeds
That is the test socket you have it plugged into.  🙂
MrColeman
Ok well that made it slower.
MrColeman
I did a speedtest (over wifi) right next to my router and I got these numbers.
I would be happy with them type of speeds, but when I tested the speeds by downloading something. The speeds once again were like 5-7 mbps.
Are you sure you are not mixing up your bits with your bytes? Connection speed is measured in Mbps, download volume in MB. There are 8 bits per byte so a file download at 5-7 megabytes per second would roughly equate to a speed of 40-56 megabits per second.
MrColeman
The package I bought advertised between 67-73 Mb, so are you telling me if they advertised 67Mbps it would be better? Either way I'm still not getting the speeds I was guaranteed.
Hi MrColeman
Is the router still connected at the test socket?
I've checked the connection stats and your line is showing in sync at 51.5mb. If the router has been at the test socket for 48hrs then I can pass this over to our Network Team for investigation.
MrColeman
No I took it out straight away cause the speeds were even slower, I'll put it in again I guess.
MrColeman
Ok it's in the test socket again.
Hi MrColeman,
Your current sync speed is 55Mbps, what are your throughput speeds like (speed test results)?
MrColeman
I'm getting a 38 download and a 16 upload. Which with the plan I'm on should be able to support streaming/downloading from multiple devices. But as soon 2 for example start watching or downloading, speeds drop and start video starts freezing or going in lower quality. Plus like I said my download has never been over 6mbps when downloading anything. Takes me a few hours to download a 20gb file for example.
Hi MrColeman,
Could I just confirm, are these devices connected wired or wireless when the throughput speed drops? As the throughput speed is also a bit lower than the sync speed, could you trying switching the router off for a full 30 minutes and then run the speed test again please.
