Switching to Faster Fibre
1 REPLY 1
Rita44
I am switching to Faster Fibre and was told my current router will work.
Do I need to do anything to set up the faster fibre?
For example install, set up or turn the current router on and off to accept the new Faster Fibre?
You can tell I am not tech savy.
Any help would be greatful.
You shouldn't need to do a thing. Expect a downtime of an hour or so on your activation date and you should be good to go.
Of course things don't always go according to plan, in which case you know where we are!  🙂
