Sync speed throttling?
Hi fothersiow
Our Network Team have advised the following:
Sync speed is 43. 6 which is within the acceptable range. Line test is passing fine, no issues seen. However I have changed DLM from stable to speed which will be effective from 05/07.
Please let us know how the connection/speed is after this date.
fothersiow
Hi, Sorry to need to re-open this thread,
but I have become aware that our broadband download speed has once again become much slower than it was a few weeks ago. - basically the same speed as we were getting earlier in the year.
This time, it seems to be throttled by TalkTalk as our line is still reported to be able to attain the much higher speed we were getting.
I would appreciate it if you could once again look to see why we are having the speeds reduced as it is most frustrating.
I attach some line statistics from our router for reference.
Fothers
Hi fothersiow,
Sorry to hear your speed has dropped again. The line management system (DLM) has moved you to a slower profile, it does this because either the connections is unstable or the error count is high.
Are you currently experiencing any problems with your telephone service? Any noise on the line?
fothersiow
Hi Chris,
I can't say that i have noticed any issues with our telephone or internet lately.
Phone calls are all clear, we haven't altered any internal wiring or equipment and the router doesn't drop connection for days at a time.
Additionally a  BT openreach engineer gave our line a great bill of health in the summer when our previous speed issues were being ironed out.
Thanks,
James
Fothers
OK thanks. Is your router currently connected to your Test Socket?
fothersiow
It is connected to the master socket but not to the test socket inside the face plate.
How long does it need to be connected to that socket for - ideally we don't want to be without phone for longer than necessary.
Fothers
It would really need to be connected to the test socket for at least 48 hours to allow DLM to respond to any improvement in connection. You can connect a telephone to the test socket too if it's more convenient
fothersiow
I have had the router connected to the test socket for the last three days.
Unfortunately the download speeds have not improved.
I have attached a screenshot with the relevant DSL diagnostics on it.
I hope you're able to help with some further investigation now.
Thanks,
James
Fothers
Hi James,
Is your router still connected to your test socket? DLM changed your profile in the early hours of this morning which has resulted in a speed increase
fothersiow
Yes i can confirm that the actual downstream speed has increased to 39998.
Also the attainable speed has increased to 49012.
So i'm not sure why it wouldn't have increased to at least it's previous speed of 45mb but it is better.
The router is still connected to the test socket at this time.
Can you let me know if there can be further improvement to match previous speeds or if this is considered a satisfactory minimum for our line?
James
Fothers
Hi James,
This is the guaranteed minimum for your line but that's not to say that the speed won't improve further, DLM generally makes small changes then monitors before making further changes
fothersiow
Hi Chris,
My line speeds have decreased again over the last few days below the minimum speed guaranteed.
Please see screenshot for current rate vs the lines attainable rate and line stats.
As i'm sure you agree, this repeated decrease in speed is not acceptable given that:
my broadband router is working correctly, Openreach replaced our master socket last summer and gave the line a good bill of health, the router remains solely connected to the test socket to remove possibilities of other line degradation within our property.
Please can you look again at what is causing this situation. If there are no courses or action left to take, we will sadly need to terminate our contract under the consumer protection regulations as soon as the line can be transferred to another provider.
Many thanks,
James
Fothers
Hi fothersiow,
I'm sorry to hear this and I'll take a look now. I've run a test on the line which hasn't detected a fault. Is the voice service currently ok with no noise on the line?
fothersiow
The voice service seems perfectly fine. No noise etc.
Fothers
Hi fothersiow,
Line test isn't picking up any issues but we can arrange an engineer visit to investiate further. If you'd like us to arrange the engineer visit can you confirm:
I've also PM'd you to confirm some other details
fothersiow
Happy to accept potential charges,
Can be flexible about visit times of the engineer to suit.
Fothers
Hi fothersiow
I've booked the engineer visit for tomorrow morning 08:00-13:00  (December 11 2019, AM) - please let us know how you get on
fothersiow
Just to report that the openreach engineer has visited, given the line a clean bill of health again and was able to see a drop in speed during october, possibly caused by some work or congestion elsewhere on the network.
He has suggested in future that TalkTalk request a DLM reset rather than calling out an openreach engineer - which sounds much more straight forward.
Thanks for helping to sort our issue again.
James
Fothers
Hi James,
Thanks for the update, please let us know if you experience any further problems
