TalkTalk Hub losing DNS
14 REPLIES 14
Repeat Guest
In the last month or so my Talk Talk hub (Sagemcom Fast 5364 firmware SG4K10002816t) keeps losing DNS both on ethernet and wifi - I have tried switching to the Google DNS servers but still does it.
Only solution I have is to reset the router. This has progressively become more frequent, so now I am resetting at least 10 times a day. I have tried leaving it off for 30 mins, issue still persists.
Any advice would be greatly appreciated
James
Hi @JamesG3 ,
For one of the TalkTalk staff on this forum to be able to look into this you will need to update your community profile to include your name, landline telephone number that your TalkTalk service is provided on & an alternative contact number. This will allow them to identify you, and they will then be able to help.
If they believe your router is faulty they will be able to send you a replacement
Repeat Guest
Thanks, I've now updated my profile details
Hi JamesG3,
Line test is clear but I can see that there have been some reconnections. Does the light change on your router when your router loses DNS?
How many telephone sockets do you have? Do you have anything connected to your telephone socket(s) in addition to your router?
Are you experiencing any problems with your telephone service, any noise on the line?
Repeat Guest
Thanks Chris.
The light remains white on the router and in the admin panel it says it is connected to the internet.
I have a single telephone socket, TalkTalk arranged Openreach to check it some months ago and they installed a new wall socket and tested the line. Nothing else is connecte to the telephone socket, I don't use a landline.
James
OK thanks James, do you have another router you can test with?
Repeat Guest
No Chris, just the TalkTalk Hub router
James
OK thanks James, would you like us to send another router to test with?
Repeat Guest
That would be great thank you - if you could send the same router then I can import all my settings.
James
Hi james,
We're trialing a new way of sending out routers, would you like to take part in the trial, it will just mean filling out a survey?
Repeat Guest
Hi Chris,
I'd rather not - just need to get the issue resolved as I am very dependent on reliable internet access.
James
Hi James
Repeat Guest
Thanks Debbie, will keep you posted
Repeat Guest
Hi Debbie,
Well I've had the replacement hub router (thanks for that) for a couple of days but the problem still persists - I've had to reset the router 3 times already today.
What would be the next move?
James
