TalkTalk Hub problems with DNS and invalid IP addresses
11 REPLIES 11
dnsnightmare
Hi there I joined TalkTalk a few days ago and I'm having problems with the hub: Hardware Version FAST5364 3.00 Software Version SG4K10001E00t First problem was that the default IP address is 192.168.1.1, which is in a different subnet than all of the other devices in my home. I thought the industry standard was 192.168.0.1 because this has been the default IP of all routers from every other ISP I've had over the years. So I eventually gained access to the router and tried to change its IP address via the Hub Settings -> DHCP page to 192.168.0.1, and the DHCP pool range to 0.10 > 0.254. But every time I edit an IP address on this page, I'm presented with a validation error "Invalid IP address". This happens no matter whether I type or paste into the field. I don't know how, but somehow I managed to change all the fields eventually and my router now has an IP of 192.168.0.1. This is where the real trouble begins. On the Hub Settings -> DNS tab, the "Primary DNS Server" remains at 192.168.1.1 and there is no way to change this. I can't turn the "Static DNS Server Configuration" OFF - clicking on the toggle switch simply does nothing. This means my devices are being given a default DNS server of 192.168.1.1 and therefore they have no web access. I have tried going to Internet Connectivity > Basic > IPv4 and choosing "Manually Specify DNS" in there, but the changes I make in there do not seem to override the "Static DNS Server Configuration" section I mentioned above, and my devices are still trying to use the now non-existent 192.168.1.1 for DNS. This is really frustrating and I've never had any problems like this from the 7 or 8 other ISPs' routers I've used over the years. Help would be appreciated. Thanks.
dnsnightmare
P.S. I did format my post with lots of line breaks but the forum has helpfully stripped them out.
All our routers have the IP address of 192.168.1.1
This is the most common configuration for routers and not unique to TalkTalk.
You can see this with the majority of router models here.
If you add your home phone number to your Community Profile I can push the later firmware to your router and see if this helps.
dnsnightmare
Hi Karl Thanks for your reply. Will the latest firmware allow me to disable the static DNS configuration? I've updated my profile so happy to give that a go. Thanks again
dnsnightmare
Another update: I've discovered that WiFi calling is also not working on our household's mobile phones (iPhones) with this router. It did work with my previous (PlusNet) router. I suspect this might also be because of the DNS issue since it screws up pretty much everything connected to the network. If its not possible to fix the DNS problem by disabling the static DNS confguration feature on this router, would it be possible to send me a different router model, please? This one is a Sagecom FAST 5364. Thanks
Hi dnsnightmare,
I'm sorry for the delay. Would you like to try the new firmware first before we send a different make and model of router for testing?
dnsnightmare
Sure, please go ahead and update and I'll report back. Thanks.
Hi dnsnightmare,
I've just checked and the firmware has been updated. Please let us know how the connection compares.
dnsnightmare
Hi Michelle Thank you for your help, but unfortunately the problem remains the same, and I'm still not able to edit or disable the static DNS configuration section in the router. WiFi calling is still also not working. Can you please try sending out a different router and I'll give that a go? Thanks again
Hi dnsnightmare
Apologies for this.
Would you like me to send another Wifi Hub or a different make and model of router for testing?
dnsnightmare
Hi Debbie Please send a different model to try. Thank you.
A Huawei router is on the way to you.
