Talktalk HG633 Modem/Router Certificate Error
8 REPLIES 8
surfrockuk
Hello!
I've been trying to set up an IP camera using port forwarding and DYNDNS through Talktalk HG633 modem router.
The problem is when I try to attach to the HG633 router web interface using its external IP address I get a certificate error :
"This Site Is Not Secure - Certificate Error"
I then have to manually click through to make it proceed but this effectively stops any attempt at port forwarding.  This works fine on another router I have tried.  Any idea if this can be fixed by Firmware Update or any another route?
SurfrockUK - Re Shoeing Rural Broadband
This is down to how strict your browser is at dealing with HTTP, all TalkTalk routers use this rather than HTTPS. I do agree is this day & age they should use HTTPS, but they don't.
surfrockuk
Thanks Keith 🙂
Yes I initially thought this was due to Chrome browser changing to HTTPS but I tried this with a Lynksys x6200 yesterday and didnt get the certificate error using the same browser on HTTP.  It worked fine with the IP camera port forward too.
I can only deduce the HG633 is at fault.
surfrockuk
Is there a firmware upgrade available?  Here is my current firmware version...
That is the latest version.
surfrockuk
OK, Cheers Keith.
Would it be possible to get a Sagem router from Talktalk?
The router is made by Sagemcom and called the FAST 5364.
Not unless you pay for it. I can manage & setup port forwarding without any issue using Chrome in Windows 10, there is nothing wrong with the router, as I said they all work http only, not https.
surfrockuk
I know what you are saying but this works fine on a different router.
I'd be happy to pay for a Sagemcom upgrade.  How would I contact a Talktalk member to organise that?
It still only works via http as all other TT router's.
