Hi all,
I have ordered the Talktalk wifi extender kit (powerline) and have a couple of questions. Will I be able to add an additional extender in the future should the need arise, if so, will it have to be a talktalk one or will a universal one be OK.
I am not sure about the use of multiple extenders. But this guide includes the following:
"Please be aware that your Wi-Fi Extender Kit is not compatible with any non-TalkTalk powerline adapters or equipment."
Hi js123
Apologies for the delay.
Have you had a look at the help page in ferguson's post?
Hi Debbie,
Yes I have, it appears you can add additional adapters, talktalk ones will definitely be compatible. So if the kit I have ordered is good I will probably order an additional kit. Although that means part of the kit (the adapter that connects to the router) will be surplus to my needs. Shame talktalk don't supply the part I would need separately.
