There's a problem with our network Your services will be affected
3 REPLIES 3
avrilbrooks
My puter is so slow so I checked my service status which came up with the following
I've just spent an hour on live chat to no avail grrr
He said he was doing some tests then said he couldn't do them to call back in 3 hours
yeah right The chat will be closed then
FritzCT
Wise Owl
Stuff happens that sometimes is not directly related to TT. Frustrating but it is what it is.
At the moment there is an issue in E Cambridgeshire that is a fault on the Openreach section of the network.
Is that you?
https://community.talktalk.co.uk/t5/Service-Status-Dashboard/bd-p/service
Fritz
Fritz
avrilbrooks
Hi Fritz
Thanks for replying
I'm in Manchester so it's def not that x
OCE_Michelle
Hi avril,
I've run a test on the line which hasn't detected a fault and the sync speed looks ok. What speeds are you receiving at the moment? I can see planned engineering work, however this may or may not be service affecting.
