Time the WiFi to turn off at night
1 REPLY 1
Hi does anyone know if it is possible to put some sort of timer on for the WiFi to go off at a certain time at night or even better just too a certain device, my son is up till stupid o’clock on his PS4 and without actually setting my alarm to wake me up and have an argument with him I don’t know what else you do. Thanks
This is not possible on any router currently, some will allow you to block his PS4, but you would have to log into the router & do this manually each day, the same goes with turning the WiFi off, but if the PS4 supports a wired connection & it is used, that wouldn't stop it.
You can try looking at the options for HomeSafe in MyAccount.
