To disable Wireless/AP Isolation?
ANSWERED
5 REPLIES 5
Hey there.
I'm trying to connect My phone and my PC together using the "Your Phone App", and I've been looking at the troubleshooting support page from Microsoft.
My phone and PC are on the same Wi-Fi network but they won't connect
If both of your devices are using the same Wi-Fi network but you still see an error message, this could be caused by a setting on your router.
Many routers have a Wireless isolation feature that allow you to lock down the network. If this Wireless Isolation (or AP Isolation) is enabled, then all devices connected to the Wi-Fi network will be blocked from communicating with other.
To disable Wireless/AP Isolation:
On most routers look for the Wireless > Advanced Wireless Setting, and uncheck/toggle AP Isolation.
I'm unable to find this option anywhere in the router settings.
If you could be of an assistance, this would be much appreciated.
Thanks,
Alex
Solution
Hi @Jeffer1 have you tried this? Split your router's SSID (wireless network name) ?
Your post has been flagged for assistance and you should hear soon.
Hi Jeffer1,
How are you getting on? Have you tried separating the SSID's?
Hi there,
My problem is fixed, thanks to Divsec!
Thanks alot for your help ❤️
Hi Jeffer1,
Thanks for the update 🙂
Hi @Jeffer1 thanks for that so glad that is sorted for you come back anytime😁
