Is there anyway to automatically turn off my wifi overnight, say 12am and back on again 6 or 7 hrs later? I saw a thread some time ago but it was not possible back then. Surely it must be an available feature now????
Solved! Jump to the Best Answer.
Have a look at the Home Safe settings in My Account on the main TT web site. If I remember correctly they have a Home Work setting that blanket blocks (as in all devices) connections for specific times.
Fritz
This could result in lower connection speeds during the day. The exchange equipment will start the process of calculating stable line speeds. Routers are designed to be left on.
Thanks for your reply. I don't want to turn off the power to the router just the wifi
Thanks for this. I have set it up to try it later 😉. It looks like it will turn off the wifi
